10 years, 8 months ago.
How to write in a file with nucleo F401RE
I'm trying to write in a file but the file can't be read even if I create it before :
- include "mbed.h"
- include <stdlib.h>
- include <stdio.h>
- define TEST "test.txt"
int main(){
FILE* fichier; if ((fichier = fopen(TEST,"w")) == NULL) Creation d'un fichier. Si apres sa création on arrive pa sà l'ouvrir alors le programme s'arrete { fprintf(stderr, "\nErreur: Impossible de lire le fichier %s\n",TEST); return(EXIT_FAILURE); }
fclose(fichier);
7 years, 8 months ago.
@Rozenn, understand this reply is 3 years late but just went through a similar exercise today in an attempt to use this LocalFileSystem with W7500 board and had the same fault.
Issue is that this support for LocalFileSystem is limited to only 2 mbed boards (your Nucleo is not on that list):
https://os.mbed.com/questions/2735/LocalFileSystem-undefined/
You need to declare and open the filesystem object first. What type of file do you want to open? https://developer.mbed.org/handbook/LocalFileSystem https://developer.mbed.org/handbook/SDFileSystem
Something else?
