11 years, 4 months ago.
Firmware upgrade Issue with Win 7
I am trying to upgrade my KL-25z's firmware from my windows 7 netbook but with no success. Unfortunately it looks like I got one of the older digikey boards that requires the firmware update to be usable from my mac.
Board info : MicroBoot Kernel Version is: 1.05 Bootloader Version is: 1.09 Application Version is: 0.00
no mbed.htm file comes up when in bootloader mode. Nothing appears connected to the computer when plugged in ordinarily
Here is what I'm trying, and the results :
1 - Hold reset and plug device into Win 7 computer - D4 LED does flash 2 - Open up BOOTLOADER drive that appears 3 - move in BOOTUPDATEAPP_Pemicro_v111.SDA to the bootloader drive's root, and wait for file to have moved 4 - Unplug board from comp, plug it back in 5 - After this I wait for up to a few minutes, but the green D4 LED does not blink at me and the bootload drive never shows up.
Other info : 1 - The board does not show up on my computer at all as a drive unless it is bootloader mode. I can't find it in devices 2 - LASTSTAT file says "Ready." when opened 3- BOOTUPDATEAPP_Pemicro_v111.SDA is not visible when re-opening in Bootloader mode 4 - PEdrivers should be installed (I went through the process and the folder shows up) 5 - The RGB LED on the board runs through a default program of a few colors and then slowly changes colors
What I may have broken : It is posible that I messed something up when first starting out since I did not initially see the note about Mac incompatibility with older firmware. So when I first got it, I plugged the board into my mac, and tried loading a generic test program over to the board. Perhaps that messed something up?
I recognize that perhaps I have just bricked the board, and it is no longer usable- in that case, is there a source to get a board with the most up to date firmware already on it?
Commenting here, so you see there is a new comment: The updated firmware is required to load new mbed firmware in the future on a mac. But tbh I wouldn't expect many important new updates for that. The mbed firmware itself works perfectly fine on mac/linux, so to load programs there is no need to latest opensda firmware, since the mbed firmware handles that part.
posted by Erik - 02 Dec 2014
The file you mention is the bootloader update, but it is not the mbed firmware. (Still it should show up as mass storage device, which is a bit weird).
The mbed firmware is linked on the handbook page you made this question: http://developer.mbed.org/media/uploads/sam_grove/20140530_k20dx128_kl25z_if_opensda.s19.zip. Do the same thing, copy that file to the bootloader drive, and it should install mbed firmware which does run on your mac.
Thank you for the fast and on-point answer! I had done this when on the mac side, but had apparently messed that process up when doing it from windows. I did what you said and moved over the s19 file while in bootloader mode (held reset), and now I can find the board as a regular drive and it has the mbed.htm file when plugging it in not as a bootloader.
However, the bootloader version does not seem to have changed when opening the sda_info file. Right after moving the new s19 file over, the green D4 LED blinks rapidly for a second, then holds green, and my computer recognizes that something different is going on (it recognizes the new drive and loads drivers). But instead of coming up as a bootloader drive, the device comes up as a regular MBED drive (and waiting for a minute does not change that). Then when I boot it back up in bootloader mode, the sda_info gives the same results as before. Plugging in in bootloader mode right after loading the s19 file also does not solve the issue, nor does using a different USB port.
I have tried this process with rev 0203 and 0201 : 20140530_k20dx128_kl25z_if_opensda.s19 and mbed_if_v2_1_frdm_kl25z.s19 respectively
Edit : Strangely, I can now load code (or at least blinky) to my board from my mac despite the sda_info file claiming the 1.09 firmware is in place. I guess I'll just mark this resolved then, thanks!
posted by Stephen Hibbs 02 Dec 2014
