10 years, 8 months ago.
How to add support for LPC4088 and LPC4337?
I would like to add support for the LPC4088 and LPC4337 so that I can make a custom PCB for them in the future. Is this possible? There is already a development board for each chip, so the settings should already be in the code somewhere? However I don't know which settings are the ones that need to be changed. Thank you.
LPC4088 https://developer.mbed.org/platforms/EA-LPC4088/
LPC4337 https://developer.mbed.org/platforms/LPCXpresso4337/
Ika_shouyu_poppoyaki doesn't support those chips at this moment.
If you need to add unsupported MCU, it may be able to be done on a file "target_table.cpp".
Next code is a table which shows supporting chips and its parameters.
Recipe for adding chip support is available in Japanese only. I'll try to find time to translate.
target_table.h
typedef struct taget_param_st {
char *type_name;
int id;
int ram_size;
int flash_size;
int sector_size;
int write_type;
unsigned int ram_start_address;
target_param;
target_table.cpp
target_param target_table[] = {
{ "unknown ttarget", 0xFFFFFFFF, 1024, 4096, 4096, UUENCODE, 0x10000200 },
{ "LPC1114FN28(FDH28)/102", 0x0A40902B, 4096, 32768, 4096, UUENCODE, 0x10000200 },
{ "LPC1114FN28(FDH28)/102", 0x1A40902B, 4096, 32768, 4096, UUENCODE, 0x10000200 },
{ "LPC810M021FN8", 0x00008100, 1024, 4096, 1024, BINARY, 0x10000300 },
{ "LPC811M001JDH16", 0x00008110, 2048, 8192, 1024, BINARY, 0x10000300 },
{ "LPC812M101JDH16", 0x00008120, 4096, 16384, 1024, BINARY, 0x10000300 },
{ "LPC812M101JD20", 0x00008121, 4096, 16384, 1024, BINARY, 0x10000300 },
{ "LPC812M101JDH20", 0x00008122, 4096, 16384, 1024, BINARY, 0x10000300 },
///added for LPC82x series
{ "LPC824M201JHI33", 0x00008241, 8192, 32768, 1024, BINARY, 0x10000300 },
{ "LPC822M101JHI33", 0x00008221, 4096, 16384, 1024, BINARY, 0x10000300 },
{ "LPC824M201JDH20", 0x00008242, 8192, 32768, 1024, BINARY, 0x10000300 },
{ "LPC822M101JDH20", 0x00008222, 4096, 16384, 1024, BINARY, 0x10000300 },
///added for LPC176x series
{ "LPC1769FBD100", 0x26113F37, 65536, 524288, SECTOR_SIZE_VALIABLE4Kx16_AND_32KxN, UUENCODE, 0x10000200 },
{ "LPC1768FBD100", 0x26013F37, 65536, 524288, SECTOR_SIZE_VALIABLE4Kx16_AND_32KxN, UUENCODE, 0x10000200 },
///added for LPC11U(E)68x series
{ "LPC11U68JBD100", 0x00007C00, 36864, 262144, SECTOR_SIZE_VALIABLE4Kx24_AND_32KxN, UUENCODE, 0x10000300 },
{ "LPC11E68JBD100", 0x00007C01, 36864, 262144, SECTOR_SIZE_VALIABLE4Kx24_AND_32KxN, UUENCODE, 0x10000300 },
Table shows type name and its parameters. The parameters can be found on usermanual and datasheet.
Thanks for the reply Tedd. I looked into it a little more, and it seems like HAPI-Tech also made some changes to the int find_sector( int data_size, target_param *tpp ) function when he added support for the LPC11U(E)68x series.
https://developer.mbed.org/users/Hapi_Tech/code/ika_shouyu_poppoyaki/rev/57ad8e04f063
Since the LPC4088 and LPC4337 are both Cortex-M4 chips with hardware floating point unit (FPU), I was wondering if there needs to be more changes than just the target_param table.
I'll look into the datasheet and manual to try and find the following information for both chips and report back. char *type_name; int id; int ram_size; int flash_size; int sector_size; int write_type; unsigned int ram_start_address;
posted by 24 Jul 2015For LPC4088 (Datahseet: http://www.nxp.com/documents/data_sheet/LPC408X_7X.pdf) type_name = LPC4088FET208; id = ???; ram_size = 524288; % 512 kB flash_size = 98304; % 96 kB sector_size = ??? write_type = ??? ram_start_address = ???
I looked into the memory map on page 52 (Table 4.), but I don't know what value to use for the ram start address. ID, sector size, and write time are also not found in the pdf. Hope this helps.
