10 years, 9 months ago.
How to send sensor(I2C) data to SD card??
Hi, Here i'm using Nucleo-L053R8 controller. I have a Temperatire and humidity sensor connected in I2C communication. Now,I'm trying to send data from sensor to SD card. How to do it?. thank you.
  1. include "mbed.h"
  2. include "ms5611.h"
  3. include "SDFileSystem.h"
ms5611 ms(D14, D15, ms5611::CSBpin_1); SDFileSystem sd(D11,D12,D13,PB_6, "sd"); MOSI, MISO, SCLK, SSEL
Serial pc(USBTX, USBRX); local terminal interface
int main (void) { pc.baud(115200); set up USB serial speed
set up the ms5611 pc.printf("\n\nInitializing the MS5611..\n"); ms.cmd_reset(); pc.printf("Ready\n"); FILE *fp = fopen("/sd/mbed.txt", "w");
while(1) { double Temp = ms.calcTemp(); calculate press and temp, then returns current temperature in degC double Press = ms.calcPressure(); calculate press and temp, then returns current pressure in mb double GetPress = ms.getPressure(); returns current pressure in mb. Does no calculations. Ususally done after calcTemp()
pc.printf("Temp: %.2f degC\n", Temp); pc.printf("Barometer: %.1f mB %.3f in/Hg\n", Press, Press * 0.0295301);
fprintf(fp,"Temp: %.2f degC\n", Temp); fclose(fp); wait(2.0); } }
would this code send data to SD card??
posted by Mohan gandhi Vinnakota 14 Jul 2015
If you try it for a while, put the SD card in you PC and see what you have.
This should work though:
snip
 FILE *fp = fopen("/sd/Templog.txt", "a");
                  fprintf (fp,"Temp: %3.3f degC\r,",Temp);
                  fclose(fp);
posted by Paul Staron 14 Jul 2015
Thank you. its working.
posted by Mohan gandhi Vinnakota 15 Jul 2015
