10 years, 9 months ago.
gas sensor
i'm working on a gas sensor from parallax(MQ-5) using mbed. i have read the details in this link below. connected the ALR to (pin5) & HSW to (pin6). Gnd to Gnd & 5V to 5V usb Out. but the pdf state that i have to set both the set point & trip level to 0.8V,but the max i can go is only 0.2 & 0.4 respectively. i have a simple program to make it working but to no avail.so my question is how do i make it to work?
https://www.parallax.com/sites/default/files/downloads/27983-Gas-Sensor-Board-Guide-v1.0.pdf
DigitalIn heat_ch4(p20);
DigitalOut alarm_ch4(p6);
    while(1)
        if (heat_ch4==1)
            alarm_ch4=1;
            printf("TRUE");
        if(heat_ch4==0)
                alarm_ch4=0;
                printf("false");
hardware connections and how to see the output
posted by krishna kumar 13 Mar 2016
Well, as I can see, you missunderstood the concept of the sensor. Heat is an input on the sensor, so you have to configure the heat pin on mbed as output. When driving the heat pin high, you'll switch on the heating of the sensor. The alarm pin on the sensor is configured as output, so you have to configure the alarm pin on your mbed as input.
DigitalOut heat_ch4(p20);
DigitalIn alarm_ch4(p6);
heat_ch4 = 1; //switch on the heating
    while(1)
        if alarm_ch4==1)
               printf("TRUE\r\n");
        else
               printf("NOT SO TRUE\r\n");
