10 years, 8 months ago.
Where are the interrupt pins on NUCLEO-F411RE?
I just got the board yesterday and I cannot find the locations of interrupt pins. Can someone help me out?
Thanks
If you use a recent version of the mbed lib (right mouse button, update in the online compiler): Every unique numbered pin. That means you can use any pin as InterruptIn, but you cannot use multiple pins with the same number on a different port as InterruptIn. So you can use PA_1, PB_2, PA_3, PC_4, etc. But in this example you could not use also PE_1.
