10 years, 9 months ago.  This question has been closed. Reason: Too broad - no single answer
Wake up using RTC
I need to generate a wake up function synchronised to the RTC but still retaining Time and Date registers, for instance every second or 10 seconds (1 second resolution), is this possible? I'm using a low power Ticker but that runs off synchronisation with the RTC by a couple of seconds per hour.
Silicon Labs' EFM32™ Wonder Gecko ARM® Cortex®-M4 based 32-bit microcontrollers (MCUs) provide flash memory configurations up to 256 kB, 32 kB of RAM and CPU speeds up to 48 MHz, …
