10 years, 9 months ago.
LPC824, RTOS and IAP
Team We had written a mbed app with a whole bunch of things including IAP for changing flash data (instead of EEPROM). All was working well and we then tried to implement RTOS Timer on it. With RTOS the program stops at IAP ERASE. Code given below
<code> result= iap.erase(targetSector, targetSector); 30th Sector
Erase is defined as
int IAP::erase( int start, int end ) { IAP_command[ 0 ] = 52; IAP_command[ 1 ] = (unsigned int)start; Start Sector Number IAP_command[ 2 ] = (unsigned int)end; End Sector Number (should be greater than or equal to start sector number) IAP_command[ 3 ] = cclk_kHz; CPU Clock Frequency (CCLK) in kHz
iap_entry( IAP_command, IAP_result );
return ( (int)IAP_result[ 0 ] ); } </code>
Any one facing this problem?
Since I am not sure the iap_entry does it automatically: try adding:
__disable_irq(); //Your IAP code __enable_irq();
If an interrupt is serviced during IAP this could be a problem.
Erik I will add the above code. Thanks for your response. I thought IAP was a ROM call.
I am using th following IAP code https://developer.mbed.org/components/IAP-In-Application-Programming/
Thanks
posted by 23 Jun 2015IAP is indeed a ROM call on LPC devices, but I don't know if the ROM code disables interrupts. For example I know for a fact that all flash access during programming/erasing of any sector results in the MCU crashing. It can handle a while(IAP_read) loop, most likely since that is prefetched from flash, for the LPC this is not relevant however since it is fetched from ROM. However if interrupts would not be disabled, it would jump to the interrupt vector where it would need to use the flash.
Note: Not a clue if this is indeed your problem :).
posted by 23 Jun 2015Erik it worked.
Does this in any way affect CRP? Couple of my devices went into CRP3 mode (as i understand from the LPC82x user manual)
posted by 02 Jul 2015
