10 years, 9 months ago.
Compile error in mbed-rtos when exporting to GCC ARM Embedded toolchain
Error info:
mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_M4/TOOLCHAIN_GCC/HAL_CM4.s: Assembler messages:
mbed-rtos/rtx/TARGET_CORTEX_M/TARGET_M4/TOOLCHAIN_GCC/HAL_CM4.s:217: Error: IT falling in the range of a previous IT block -- `ite EQ'
Cause:
GNU AS does NOT recognize C preprocessing keywords.
Workaround:
Change the Makefile to use GCC instead of AS for assembly source files.
.s.o:
#	$(AS) $(CPU) -o $@ $<
	$(CC) $(CC_FLAGS) $(CC_SYMBOLS) -std=gnu99 -x assembler-with-cpp $(INCLUDE_PATHS) -o $@ $<
Thank you !
posted by Robert Spilleboudt 23 Jun 2015
Same problem here. Thanks for postings this.
posted by Mateusz Kaduk 23 Jun 2015
