10 years, 7 months ago.
Using the library on the FRDM-K64F
Hello, Can this library used with the FRDM-K64F board? I have a DSP device that acts as a master, and I need to send audio to it (actually, play some tones and pre-recorded wave files). Is that possible with this library on that board?
Regards, Yair
That library is specific for the LPC1768, so sadly you cannot use it. You can search around a bit, but I couldn't find one for the K64F, so you will need to make one yourself if you want to use it.
9 years, 1 month ago.
Dear Yair,
I am interesting related topic. So, i would like to ask, have you found I2S lib for K64F? or you write one already?
I found this project come with I2S, it seem for K64F, have you try it? https://developer.mbed.org/components/ARD-AUDIO-DA7212/
Mind share your experience? Thanks.
Thanks for your message. I've stopped looking for I2S library for this board a long time ago, as I found alternative ways to achieve my goals (not mbed related). The project you mentioned looks interesting though. I'll look into it; maybe I will be able to use it in the future. If you want to discuss it further, you can contact me directly at: yair@innovo-concepts.com
Thanks, Yair
posted by Yair Raz 23 Dec 2016
I tried, but it has problems with executing lines such as "PORTC->PCR[5] &= PORT_PCR_MUX_MASK;"
posted by JJ - 29 Mar 2017
