10 years, 10 months ago.
Compiler error 230
Upto 67kb (file size after compilation) my program was compiling successfully, but after some modifications i think it exceeded 67kb.Now it is not compiling and showing the following error
Warning: The build system is under heavy load right now. Compiles may take longer than usual.
Error: The build system did not finish successfully.
Hi Archana,
I had faced this problem sometime back. I think it is because too many users might be trying to use the online compiler. Please try after sometime.
Regards, Lakshmanan.
Thank you Sir,
But I have tried multiple times , and still the problem exists.
posted by ARCHANA SREEKUMAR 04 Jun 2015
Hi, I am not sure what might be causing this problem. Please can you contact the MBED support team? Their e-mail ID is : support@mbed.org. Good luck !!
posted by Lakshmanan Gopalakrishnan 04 Jun 2015
