10 years, 9 months ago.
How to drive an output pin voltage?
Hi everyone, I wish to drive a voltage signal to an output pin of my STM32L053 Nucleo board. The intention is to keep such a pin tension high or low for a random time length, its duration no shorter than a minimum time, no longer than a maximum one. Before I get back browsing through hundreds pages of digital manuals, do you have a suggestion what to search for, what to focus on, what to code precisely? Thanks in advance for any hint and suggestion. Regards, ANdrea
My web page
https://sites.google.com/site/johnkneenmicrocontrollers/input_output/io_f107#linkconfig_107
may give some ideas. The link is for a different STM device but may give you some ideas.
1. You need to enable the clock to the peripheral of interest 2. You need to configure the pin as an output. 3. You need to set/clear pin to required state.
JK
I would start with looking through the handbook pages, since just DigitalOut allows you to set a pin high or low.
Part 2 is creating a random number, and when you got that, map that to your minimum/maximum time.
Hallo Erik. First, thanks for your answer. Second: do you have any specific handbook in mind, you suggest to dive into?
posted by 29 May 2015The mbed handbook pages were the ones I meant: https://developer.mbed.org/handbook/Homepage
https://developer.mbed.org/handbook/DigitalOut
