11 years, 4 months ago.
Non Consecutive Sectors!! Fail.txt!! Help me solve this please
I really don't understand what led to the problem. My kl25z does not get flashed. I tried loading the boot loader again, tried giving external supply and flashing it, doesn't work. A text file generated in the MBED folder shows me "Non Consecutive Sectors". I even tried answers in this forum, but in vain.
Please let me know if I can try and solve with this issue.
Assigned to 11 years, 4 months ago.
What computer and OS version are you using?
posted by Sam Grove 24 Nov 2014Its solved!! Not a concern with the OS used... I went to the boot loader mode, loaded CMSIS, used code warrior to execute a sample code, loaded MBED file again.. And ya!! Its ready now.. But I am still not able to know the root cause of thw problem..
posted by Ram Prasadh 25 Nov 2014sorry but can you elaborate a bit more? im having the same problem with my kl25z and dont have code warrior thanks
posted by Efrain Caballero 09 Oct 2015Sorry taking so long to answer you Elfrain. Don't know if you still need help but some people might. You may use Keil in order to erase the memory and unlock your board.
posted by Thiago . 26 Nov 2015
