10 years, 10 months ago.
Not able to read data from Flash
Hi!!
I've encountered a problem in reading data from a flash sector where i wrote previously. The first program i've loaded on my K22F is the library example:
#include "FreescaleIAP.h"
int address = flash_size() - SECTOR_SIZE; //Write in last sector
int *data = (int*)address;
printf("Starting\r\n");
erase_sector(address);
int numbers[10] = {0, 1, 10, 100, 1000, 10000, 1000000, 10000000, 100000000, 1000000000};
program_flash(address, (char*)&numbers, 40); //10 integers of 4 bytes each: 40 bytes length
printf("Resulting flash: \r\n");
for (int i = 0; i<10; i++)
printf("%d\r\n", data[i]);
printf("Done\r\n\n");
while (true) {
Then i will write to an other sector and want to read from the previous sector:
int sizeflash = flash_size();
printf(" Flash Size: %d\r\n",sizeflash);
int sizesector = SECTOR_SIZE;
printf("Sector Size: %d\r\n",sizesector);
int address01 = flash_size() - (SECTOR_SIZE*2);
int *data01 = (int*)address01;
int address = flash_size()- SECTOR_SIZE;
printf("Address01: %d\r\n",address01);
printf(" \r\n");
printf("Address: %d\r\n",address);
printf(" \r\n");
erase_sector(address01);
int numbers[10] = {5,6,7,8,9,15,777,91,2,88};
program_flash(address01, (char*)&numbers, 40);
printf("Resulting flash for address01\r\n");
for(int i=0;i<10;i++)
printf("%d\r\n", data01[i]);
printf("\r\n");
printf("Resulting flash for address\r\n");
while (true) {
I load these programs in sequency.
Where is the error?
Thank you!!
Just checked it with just running the first program for a second time, but with the erase and program part commented out. That gave the same result. I am pretty sure this doesn't happen on the KL25 for example, not 100% sure though.
So it looks like the drag and drop loader performs a complete chip erase when programming.
The first printf works properly and returns "5,6,7,8,9,15,777,91,2,88". The second one returns me ten times "-1".
posted by giacomo amici 25 May 2015
