10 years, 10 months ago.
Touch Screen Calibration
The PUB_RA8875_TouchColors is working fine on the 8" screen.
However the touch screen calibrate will often do a auto insert of the value on the 3rd "cross" or user input. It uses the value fron the second input. Will need some debouncing
Kim
Hi Kim,
Here's the code, and you see a simple 20 ms delays. I'll suggest you make changes to this and rebuild the library - see if it then meets your needs. As you see, there is not a reason the 3rd target should behave different than the 2nd.
    for (int i=0; i<3; i++) {
        foreground(Blue);
        printf(" (%3d,%3d) => ", pTest[i].x, pTest[i].y);
        line(pTest[i].x-10, pTest[i].y, pTest[i].x+10, pTest[i].y, White);
        line(pTest[i].x, pTest[i].y-10, pTest[i].x, pTest[i].y+10, White);
        while (!TouchPanelA2DFiltered(&x, &y) && timeout.read() < maxwait_s)
            wait_ms(20);
        pSample[i].x = x;
        pSample[i].y = y;
        line(pTest[i].x-10, pTest[i].y, pTest[i].x+10, pTest[i].y, Black);
        line(pTest[i].x, pTest[i].y-10, pTest[i].x, pTest[i].y+10, Black);
        foreground(Blue);
        printf(" (%4d,%4d)\r\n", x,y);
        while (TouchPanelA2DFiltered(&x, &y) && timeout.read() < maxwait_s)
            wait_ms(20);
        wait(2);
Hi David
In RA8875_Touch.cpp I have changed the above loop to the following:
        //set text colour
        foreground(Blue);
        //Print test co-ordinates to tft screen
        printf("Test Co-ordinates (%3d,%3d) => ", pTest[i].x, pTest[i].y);
        //draw cross on screen in white
        //wait for filtering or timeout
            wait_ms(20);        //time to allow screen to process touch screen data
        //save captured touch screen numbers. pSample[3] is an array of 3
        pSample[i].x = x;
        pSample[i].y = y;
        //erase cross on screen by drawing it again using back ground color
        //reset text color
        foreground(Blue);
        //Print touch result data to tft screen
        printf("Touch Result (%4d,%4d)\r\n", x,y);
        //wait for user to move finger of screen
        wait(1);
As I'm not much of a C programmer, it's likely that the above is incorrect. But it seems to be working just fine. It seems that all the touch screen debounce filtering is done in TouchPanelA2DFiltered.
Thanks
Kim
posted by K P 30 May 2015
