10 years, 10 months ago.
Is the LCD library thread safe to used with RTOS
Are there any issues with using the RA8875 with the mbed RTOS (or any RTOS's)
Thanks Kim
Hi Kim,
I derived this library from other libs on this site, and as you'll see from this thread running under the RTOS has been talked about - and there are no known issues.
For my needs, I've got a few projects using the RTOS and this display library - but my larger problem has been in effective use of the RTOS; task stack frames, heap management, and the relative [in]ability to assess free memory.
Thanks Any suggestions about setting up the rtos for use with LCD lib Kim
posted by K P 20 May 2015
As a small follow-on, one of my projects has a couple of threads, and I was unsure if I needed it, but I create a semaphore that the threads would take before sending commands to the display, releasing the sema when done.
posted by David Smart 20 Feb 2017
