11 years, 5 months ago.
Does anyone know the manufacturer and/or model number for the pushbutton used on the mbed LPC1768?
I was looking for the details on the nice pushbutton on the mbed LPC1768. It has only the word "France" on it in tiny lettering. They work great on breadboards and I need several hundred of them for a class.
/media/uploads/4180_1/pbut.png
I found one retail source at Parallax, but was looking for a quantity discount. It seems to be the through hole PCB version of the same pushbutton.
The buttons that are used on mbed-005.1 (LPC1768) assembly is a KSC341G LFS from C&K Components
http://www.farnell.com/datasheets/1707722.pdf
As we manufacture many of mbed boards, maybe we can also offer our services to you if you require it. Please visit our site and check the products.
http://www.l-tek.si/EN/gallery/our-products
Found them at Digikey. Thanks for everyone's help. The first response from Martin also helped since I found out they are all listed under "Tactile Switch" in catalogs and not "pushbutton." I even can see the word "France" on that style of CK switch in the photo below from Digikey. http://www.digikey.com/product-detail/en/KSA0M411LFT/401-1813-ND/1003885 seems to be the one although the base on mine is black plastic and appears to be this version at http://www.digikey.com/product-detail/en/KSA0M911LFT/CKN9954-ND/2057205 with a bit more rated contact operations. Apparently, only some of the C&K tactile switch models come from the Jeanrenaud switch company of Dole, France and those must be the ones with "France" on them.
/media/uploads/4180_1/ckts.jpg
posted by jim hamblen 06 Nov 2014
The B3S-1000 from Omron might do the trick? Did you want SMT or through hole?
Though hole for use on a breadboard. Found them at Digikey. http://www.digikey.com/product-search/en?FV=ffec38b3 those also look like they would work. Helpful to know that they are all called "tactile switch"!
