11 years, 7 months ago.
About the TX power output of the BlueNRG
I would like to know the purpose of the modification of the TX value is the main fonction. Is there an issue when a board is used at max level?
Thanks, Julien
Hi, apparently there were some issues with the BLE Link when operated at default Tx power level. This issue should be covered/solved over the next iterations of the BlueNRG X-Nucleo and setting the Tx Power to lower levels should not be necessary any more.
Regards, Mridu
