11 years, 5 months ago.
micro SD Card type?
Hello, since the FRDM-K64F has already a micro SD card slot, which type of micro sd card can I use? SD, SDHC, UHS,...? Max 4,8,16,... GB?
Thanks Bye Jack
The Freedom-K64F is an ultra-low-cost development platform for Kinetis K64, K63, and K24 MCUs.
I haven't seen it defined in the user guide for example http://www.freescale.com/files/32bit/doc/user_guide/FRDMK64FUG.pdf. I used 4GB for demo purposes, did not have any problems. I would also check SD Card library you wnat to use, filesystem if there are any limits.
I believe SD, SDHC should be fine up to 32GB.
0xc170
