11 years, 6 months ago.
Compiler error when using a K64F
Hello MQTT Team,
I tried compiling "HelloMQTT" using a K64F without a LCD. I commented out every line in main.cpp that has to do with the LCD. There are 2 compiler errors in main.cpp as a result:
Error: Identifier "data" is undefined in "main.cpp", Line: 68, Col: 5
Error: Identifier "message" is undefined in "main.cpp", Line: 83, Col: 5
The odd thing is, if I put back the LCD stuff and rename the LCD pins to something the K64F likes (placebo pins), the program compiles without error.
//C12832 lcd(p5, p7, p6, p8, p11);   //for the original program using a LPC1768
C12832 lcd(PTE3, PTE1, PTE2, PTE4, PTE6)  //dummy pins for the K64F
...kevin
Never mind - I found the issue. However, please report back with an answer so I can close this question out ...kevin
posted by Kevin Braun 07 Oct 2014
What was the issue?
Sam, what if I update HelloMQTT to print only to one location, either stdout, or the LCD. And you can switch to the LCD with a #define?
posted by Ian Craggs 08 Oct 2014
I failed to comment out the prior IF statement above the failing lines
...kevin
posted by Kevin Braun 08 Oct 2014
