11 years, 5 months ago.
Why there are only header files (.h)?
There are only the definitions of the classes/functions/etc in these hedaer files. Where is the syntax of these classes/functions/etc (.c or .cpp files)?
And how can the code be compiled without the c/cpp files?
posted by Manos Kav 01 Oct 2014
You only need header files for a pre-compiled library which is why there are no cpp files..
If you want the full code then take a look at http://mbed.org/users/mbed_official/code/mbed-src/
If you use mbed-src in place of the standard mbed library the results should be identical but take a little longer to compile. However the src library is the live development branch of the code rather than a tested stable release so this isn't recommended if you can avoid it.
Thank you. Just wanted to see them for programming purposes only.
