11 years, 7 months ago.
How to change text size?
Could you please help me. If i use gOled.setTextSize(2) - no image on display.
If i use gOled.setTextSize(1) - all ok.
11 years, 5 months ago.
Hi Dimitry,
You need to add the WANT_ABSTRACTS define, then you will be able to use text sizes greater than 1.
I have published a fork of the library with that set.
Dan
Thanks Dan for answering this.
Dimitry, since you Accepted this Answer, I have made several changes, including documentation and I2C import.
You may want to update to the current revision and look in the Adafruit_GFX_config.h file for GFX_SIZEABLE_TEXT or GFX_WANT_ABSTRACTS
Cheers
posted by 26 Oct 2014
