11 years, 7 months ago.
Configuration of xbee
I'm trying to establish communication between a x bee connected to a laptop by ftdi, and an xbee in the mbed board, are there some necessary previous configuration for the Xbee's?
If you didn't buy the units preconfigured then you may need to use a program call xctu to set them up, I think It's also possible to do so using special serial commands.
https://learn.sparkfun.com/tutorials/exploring-xbees-and-xctu
Well in fact I have communication between both x bee modules (using XCTU), but when I plug one of the xbee modules to the lpc4088 Quick start board, I can't have communication (Using the terminal TERA TEM and the code XBee test), so my question is towards if it is necessary to use some particular configuration on the XBee's to be able to use them with the LPC4088.
posted by Jonathan Manrique 02 Sep 2014
