11 years, 8 months ago.
I tried to save mbed firware, now my application version is 0.00.
Hello everyone.
I got a FRDM-KL25Z board and I tried to save the mbed firmware following the instructions that are explained here http://mbed.org/handbook/Firmware-FRDM-KL25Z
Then, after copying the s19 file, I unplug and plug again the board, but nothing happens not even the green led is blinking. I attempted to rollback doing the following:
- In bootloader mode, drag and drop the BOOTUPDATEAPP_Pemicro_v111 file.
- Power cycle.
- In bootloader mode, drag and drop the MSD-DEBUG-FRDM-KL25Z_Pemicro_v114 file.
- Unplug and plug it again in application loader, but as I said before, nothing happens.
When I open the "SDA_INFO.htm" it says:
Board Name is: FRDM-KL25Z
MicroBoot Kernel Version is: 1.05
Bootloader Version is: 1.09
Application Version is: 0.00
The bootloader version should be 1.11 as I "installed" it but it keeps in 1.09, and the same happens to the Application loader.
Any suggestions?
Thanks.
P.S: In bootloader mode, the little green led blinks like 8 times a bit fast, and then waits 3 seconds to blink again. P.S.1: My OS is Win8.1
Assigned to 11 years, 8 months ago.
After all this evenings trying to fix this, I solved it so I'll write it in here so maybe I can help someone :). I just had to install de Application loader "MSD-DEBUG-FRDM-KL25Z_Pemicro_v114" in my Windows 7 laptop and now my Win 8.1 recognizes the board in application mode. Eventhough I had the usb drivers for windows 8.1, it seems that it's still kinda bugged.
posted by Jose Antonio 02 Jul 2014I have had the same issue with the KL series: I am sure it is possible to make it work under windows 8.1, but really the easy solution is to just do the complete firmware update once in an older windows version.
posted by Erik - 02 Jul 2014Hi Jose Antonio.
I have the same problem, im using too 8.1 sofware. I will try this Thank u so much
posted by Andrés Jején 28 Dec 2014Hi Jose Antonio, Thanks for telling us that, I am having the same problem here.
posted by Thiago . 04 Feb 2015
