11 years, 10 months ago.
where to import a working rpc.h and related files from???
hi, i am trying to implement the RPC_Serial.cpp program given above for LPC11U24 platform for a simple python interface over serial. after compiling i get the following Error: Cannot open source input file "rpc.h": No such file or directory in "main.cpp", Line: 2, Col: 17 i tried fixing it by importing mbed-rpc library but run into whole new set of errors... help me out,
what are the errors? Perhaps the application uses old API from RPC? can you share more, your repository ?
posted by Martin Kojtal 19 Jun 2014
hi Martin, the link to the repository is: http://mbed.org/users/bhavik/code/RPC_Serial/ . i have used the example RPC_Serial code given in the tutorial as it is. still cant get it to work. thsnks.
posted by bhavik gala 19 Jun 2014
hi Martin, the error was that i was using old examples for the mbed-rpc library. now i have changed my code according to the new library following this codes: 1) http://mbed.org/questions/536/Any-working-examples-for-he-new-mbed-rpc/ 2) http://mbed.org/questions/641/add_rpc_class-member-function-not-found/ .however i am getting this new Error: Identifier "RpcAnalogOut" is undefined in "main.cpp", Line: 9, Col: 24 . i checked the RpcClasses.h file it contains the following code:
code snippet from RpcClasses.h
#if DEVICE_ANALOGOUT
class RpcAnalogOut : public RPC {
public:
    RpcAnalogOut(PinName a0, const char *name=NULL) : RPC(name), o(a0) {}
    float read(void) {return o.read();}
    void write(float a0) {o.write(a0);}
    void write_u16(unsigned short a0) {o.write_u16(a0);}
    virtual const struct rpc_method *get_rpc_methods() {
        static const rpc_method rpc_methods[] = {
            {"read", rpc_method_caller<float, RpcAnalogOut, &RpcAnalogOut::read>},
            {"write", rpc_method_caller<RpcAnalogOut, float, &RpcAnalogOut::write>},
            {"write_u16", rpc_method_caller<RpcAnalogOut, unsigned short, &RpcAnalogOut::write_u16>},
            RPC_METHOD_SUPER(RPC)
        return rpc_methods;
    static struct rpc_class *get_rpc_class() {
        static const rpc_function funcs[] = {
            {"new", rpc_function_caller<const char*, PinName, const char*, &RPC::construct<RpcAnalogOut, PinName, const char*> >},
            RPC_METHOD_END
        static rpc_class c = {"AnalogOut", funcs, NULL};
        return &c;
private:
    AnalogOut o;
#endif
is it right??? how to remove the error??? this is my code repo: http://mbed.org/users/bhavik/code/RPC_Serial_new/
posted by bhavik gala 20 Jun 2014
