11 years, 9 months ago.
while using rpc interface library i get rpc.h not found. where can i find the libraries?
Error: Cannot open source input file "rpc.h": No such file or directory in "RPCInterface/RPCFunction.h", Line: 34, Col: 17
11 years, 1 month ago.
Hello!
If you import this program: http://developer.mbed.org/users/MichaelW/code/RPC_Serial/ And use Revision 1. (You can click on Revision on the top bar of your compiler, chose Revision 1 and than click switch) The RPC Interface Library still works.
In the new mbed-rpc library there is already an existing header for a Custom RPC function (Didn't use it though because I need to use Matlab, and the Matlab library only works with the old versions).
Hope this could be of help for somebody with a similiar Problem.
Note: I'm not the one who figured this out. The one who helped me out here was the User Andy A.
Best Regards
Did you import RPC library to your project? Which example did you follow?
posted by Martin Kojtal 17 Jun 2014hi Martin, i imported the RPCInterface library ( http://mbed.org/cookbook/RPC-Interface-Library ). i followed the serial example given there. compiling it gives the above said error. i tried importing the mbed-rpc library which gave the following error: Error: Identifier "parse_pins" is undefined in "mbed-rpc/Arguments.cpp", Line: 79, Col: 12
posted by bhavik gala 17 Jun 2014I have the same Problem... I imported the RPC-Interface-Library from this page and get the same error as bhavik gala. Also the mbed-rpc Library isn't working because there are .h's missing.
Did someone figure out where the missing rpc.h is?
posted by Florian B 16 Feb 2015Hi Florian, you can refer the following answers for:
http://developer.mbed.org/questions/3827/where-to-import-a-working-rpch-and-relat/
http://developer.mbed.org/questions/3897/AnalogIn-not-working-in-rpc/
it worked for me. let me know if works for you as well... Regards, Bhavik N Gala
posted by bhavik gala 25 Feb 2015
