11 years, 9 months ago.
Can't read analog values from an RC aircraft radio receiver
Hey friends, this is Metin.
I'm trying to write a code that reads analog values from a receiver and directly writes them to the servos of the aircraft but I couldn't even read analog values. All I read(I'm debugging with Teraterm) is 0.000000.
Receiver output is between 2.3V and 4.6V. I'm using Seeduino Arch Pro. Receiver and board works properly. My code is down below. Please take a look.
Regards
while(true)
Serial pc(USBTX, USBRX);
AnalogIn aileron(P0_23);
PwmOut aServo(P2_2);
float temporary = 0.0;
temporary = aileron.read();
aServo.write(temporary);
pc.printf("Aileron: ");
pc.printf("%f\r\n", &temporary);
wait(1);
Assigned to 11 years, 9 months ago.
First of all, you can place the Serial, AnalogIn, PwmOut and float declarations outside the main() function. Secondly, pc.printf("%f\r\n", &temporary); does not print the value of the temporary variable but the address of this variable, so you need to remove the &.
posted by Frank Vannieuwkerke 07 Jun 2014
