11 years, 10 months ago.
Classes question
Dear all,
I am planning to create an application that will write on a text LCD through a I2C IO Expander (PCF8574).
I have a custom made library for generating a menu functionality on a display, still I would also like to write data from the main procedure or other function from different cpp files.
The question is how to achieve this in the right way.
What I have tested already, was to create a "common.h" with the following content (and load it in every .h file):
common.h file
#ifndef __COMMON_H_INCLUDED__ #define __COMMON_H_INCLUDED__ #include "mbed.h" I2C i2c_bus_2(PTE0, PTE1); TextLCD_I2C lcd(&i2c_bus_2, 0x40, TextLCD::LCD20x4); // I2C bus, PCF8574 Slaveaddress, LCD Type #endif
Reading about C++ classes I found out that this is not a healthy way for some reasons. Could you please guide me or explain how to create my application the right way.
Thanks, Mircea.
Hi Mircea Murar,
don't place objects (variable, class, etc..) definitions in a header file, you might end up with multiply definitions (waste space) .
You can create an object in one code file (translation unit) globally and export it through declaration in a header file, so it becomes visible to other translations units.
The examples can be found here for example http://mylinuxbook.com/the-concept-of-extern-variables-in-c/.
The another way to do it, it's to create it locally (on stack/heap), and pass it around the program as parameter using a pointer type.
See this question http://programmers.stackexchange.com/questions/222626/is-it-better-to-use-an-external-variable-or-to-pass-around-a-pointer
0xc0170
So in this instance you would want:
common.h
#ifndef __COMMON_H_INCLUDED__ #define __COMMON_H_INCLUDED__ #include "mbed.h" #include "TextLCD_I2C.h" // the header file that defines your LCD driver extern I2C i2c_bus_2; extern TextLCD_I2C lcd; #endif
main.cpp
#include "common.h" I2C i2c_bus_2(PTE0, PTE1); TextLCD_I2C lcd(&i2c_bus_2, 0x40, TextLCD::LCD20x4); // I2C bus, PCF8574 Slaveaddress, LCD
This way anything that includes common.h can assess both i2c_bus_2 and lcd directly but they are only declared in a single file.
posted by 30 May 2014
