11 years, 7 months ago.
Re-invoke USB bootloader on LPC11U68
Hey guys, I've been using the following code to re-invoke the USB bootloader on the LPC11U35 QuickStart Board, but it doesn't work on the LPC11U68. I believe *((unsigned int *)(0x10000054)) = 0x0; may be the problem, since I remember reading somewhere that this magic address was different between the LPC11U2X and LPC11U3X microcontrollers. Anybody have any ideas?
/* This function resets some microcontroller peripherals to reset
* hardware configuration to ensure that the USB In-System Programming module
* will work properly. It is normally called from reset and assumes some reset
* configuration settings for the MCU.
* Some of the peripheral configurations may be redundant in your specific
* project.
void IAP_ReinvokeISP()
//Make sure USB clock is turned on before calling ISP
LPC_SYSCON->SYSAHBCLKCTRL |= 0x04000;
//Make sure 32-bit Timer 1 is turned on before calling ISP
LPC_SYSCON->SYSAHBCLKCTRL |= 0x00400;
//Make sure GPIO clock is turned on before calling ISP
LPC_SYSCON->SYSAHBCLKCTRL |= 0x00040;
//Make sure IO configuration clock is turned on before calling ISP
LPC_SYSCON->SYSAHBCLKCTRL |= 0x10000;
//Make sure AHB clock divider is 1:1
LPC_SYSCON->SYSAHBCLKDIV = 1;
//Prepare the command array
m_Command[0] = 57;
//Initialize the storage state machine
//Set stack pointer to ROM value (reset default)
//This must be the last piece of code executed before calling ISP,
//because most C expressions and function returns will fail after the stack pointer is changed.
__set_MSP(*((unsigned int *)0x00000000));
//Invoke IAP call...
IAP_Entry(m_Command, m_Result);
//Shouldn't return
while(1);
11 years, 6 months ago.
Following code works with LPCXpresso11U68. I got a CRP DISABLED mass storage by this program.
#define IAP_ENTRY_LOCATION 0X1FFF1FF1
typedef void (*IAP_ENTRY_T)(unsigned int[5], unsigned int[4]);
void IAP_Entry(unsigned int cmd_param[5], unsigned int status_result[4])
((IAP_ENTRY_T) IAP_ENTRY_LOCATION)(cmd_param, status_result);
void IAP_ReinvokeISP(){
uint32_t command[5], result[4];
SCB->VTOR = 0;
LPC_SYSCON->SYSAHBCLKCTRL |= 0x14440;
command[0] = 57;
IAP_Entry(command, result);
IAP_ReinvokeISP();
Thanks, I'll give this a try tomorrow. Just curious, but what does SCB->VTOR = 0 accomplish?
posted by 08 Jun 2014When any interrupt is defined (e.g. using Ticker or wait etc), VTOR is remapped to bottom of SRAM area. "SCB->VTOR = 0;" sets the value by default.
posted by 08 Jun 2014@NEIL - VTOR = 0, means vector table offset is to the address 0. More information : http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dai0321a/BIHHDGBC.html
After some further experiments, it seems that
posted by Neil Thiessen 23 May 2014*((unsigned int *)(0x10000054)) = 0x0;and__set_MSP(*((unsigned int *)0x00000000));have no effect on the LPC11U35. Are these lines just a carryover from an older LPC series? Anyway, removing them still doesn't fix the LPC11U68, it seems to be resetting rather than starting the bootloader... In fact, if I hold down the ISP button while trying to re-invoke ISP the bootloader runs, so it's definitely resetting.
