11 years, 9 months ago.
Multiple Instances of SPI1 Signals
Hello All,
I see two or more instances of SPI1 signals in the header pin-out diagrams for the ST Nucleos. For instance, on the L152RE diagram shows SPI1 MISO on PA_6, PB_4, and PA_11.
Does this mean that these three pins always carry the same signal when SPI1 is in use? In other words, can I attach an SPI peripheral's MISO line to any of these three pins and get the same results?
Many Thanks, Laz
It means you can use either of those sets of pins with SPI1 (So just a regular SPI object), but you can't use them at the same time. Only those you actually set in your SPI definition will be active, the others you can use for other functions.
