11 years, 11 months ago.
Can I have more comment on my MODSERIAL question from MODSERIAL USERS?
My question:
https://mbed.org/questions/448/Error-in-txIsBusy/
Problem is Andy has been inactive for a year or so, so he won't be updating the lib. I do have a copy with KL25Z support, but if you want you can try it (https://mbed.org/users/Sissors/code/MODSERIAL/), check if your fix still does what it should do, and either make a pull request or put the code here, and then I modify it.
Your code with other processor support is nice work but I think you have inherited the same problem there. I think it is easy for you to modify it. I'am not very skilled to work with pull requests.
posted by 11 May 2014It is easy for me to modify, but not easy for me to test if it is correct with the modification ;).
I did change it (http://mbed.org/users/Sissors/code/MODSERIAL/rev/a65f89de75c5), do you have the option to verify if this works for you?
