11 years, 11 months ago.
Corrupted data Serial USART1 Nucleo F103RB
I had some problems with corrupted data from Serial usart1(PA_9, PA_10) With nucleo F103RB another serial default Serial pc(SERIAL_TX, SERIAL_RX); works very well, but when a put the follow code
/media/uploads/moisesmarangoni/code_nucleof103rb.png
/media/uploads/moisesmarangoni/error_nucleof103rb.png
Affordable and flexible platform to ease prototyping using a STM32F103RBT6 microcontroller.
It appears that your java application is running at 9,600 bps, but are you setup for 8 data bits, no parity, 1-stop bit and no hardware flow control?
posted by Abraham Howell 01 May 2014
11 years, 10 months ago.
Make sure your java application is setup for the default serial parameters of 8 data bits, no parity, 1-stop bit and no hardware flow control. Not sure how you are physically connected to PA_9 & PA_10 (serial to usb convertor, WiFi or Bluetooth module, etc), but make sure that the wires have a good connection with the Nucleo pins and be sure to connect a common ground wire.
Regards, Abe
