11 years, 12 months ago.
trasfering data between ST Nucleo F401RE
is there another way to transfer data between several stms, if the slave mode is not supported? they cant all be masters when they have to share the same clocks, I am stuck and i don't even know where to go if i2c and spi slave modes aren't supported
The nucleo devices are recent additions to mbed and the libs are still under development. There are several options to tackle your requirements: wait for STM or someone else to add slave functionalities to the lib, add these features yourself or use serial port functions and rs485 drivers. The serial ports can read and write, transmission speed is similar to regular I2C. You dont get hardware support for addressing out of the box, but this can also be implemented in your software.
thanks, I wish i could but i'm having a hard time finding a guide on how to do it.
posted by 13 Apr 2014thanks, I wish i could but i'm having a hard time finding a guide on how to do it.
posted by 13 Apr 2014You will find several examples on this site when you do a search for rs485. Such as this example. You need to connect the TX and RX pins to a RS485 driver chip such as the MAX485, The datasheets for the drivers provide information and schematics.
posted by 14 Apr 201411 years, 12 months ago.
Hello, The SPI slave and I2C slave are still in development/test. We want to be sure that all is ok before publishing them on GitHub. It should be ready in the next couple of weeks. Regards
