12 years ago.
Device registration not correct
First time really using an NXP ARM dev / mbed board. Really like NXP. I got an LPC812 board from today's EELive! show.
I replaced the firmware.bin when the board boots up with a new firmware that I found from mbed.org/handbookFirmware-LPC800-MAX. It's basically the mbed_if_v2.0_lpc800-max.bin file that I replaced the old firmware with for the LPC812 board.
The firmware replacement seems to work, as the board boots up with the mbed.htm file, and I double click on it. But, I get the below. Please advise. Thank you!
Sorry, there was a problem with the device registration code supplied.
Please contact support@mbed.org for more information.
LPC800-MAX from NXP is an mbed enabled platform which combines the advantages of the mbed ecosystem and Arduino form factor.
12 years ago.
That shouldn't happen I guess, but also not something to worry about. Go to https://mbed.org/platforms/NXP-LPC800-MAX/, and there should be a button for you 'add to compiler', That does the same as that mbed.htm file is supposed to do.
