13 years, 2 months ago.
Open for Collaboration?
Hi there,
Apparently, mbed supports collaboration for code projects now: http://mbed.org/handbook/Collaboration
The community could help you make improvements to this library to improve it. For example, Android devices can have protocol version 2, not just version 1 as is hardcoded into the library.
Would you like to consider inviting developers to contribute to AndroidAnccessory?
Thanks so much,
Liz
Should Giles decide, for whatever reason, that he doesn't want to allow people access to his AndroidAccessory repository you are still able to import the program and edit it in your workspace. Once you have made the changes you want you can publish your own AndroidAccesory in a fork (tutorial here).
Giles could then decide to pull the changes you've made into his own repository (tutorial here)
