11 years, 12 months ago.
confused about xbee mbed rx code
hey ppl.. i need to write a code where one xbee+mbed is trasmitting a particular character (say "A") and the other mbed+xbee is receiver and if it receives "A" then any one of the Led shld glow
i tried writing the code of tx.. but confused abt the RX code
TX code
Serial xbee1(p9, p10);
DigitalOut rst1(p11);
DigitalOut myled(LED3);
DigitalOut myled2(LED4);
Serial pc(USBTX, USBRX);
rst1 = 0; //Set reset pin to 0
myled = 0;//Set LED3 to 0
myled2= 0;//Set LED4 to 0
wait_ms(1);//Wait at least one millisecond
rst1 = 1;//Set reset pin to 1
wait_ms(1);//Wait another millisecond
while (1) {//Neverending Loop
if (pc.readable()) {//Checking for serial comminication
myled = 0; //Turn Led 3 Off
xbee1.printf("A"); //XBee writes "A"
myled = 1; //Turn Led 3 on for succcessfull communication
RX code
DigitalOut rst1(p8);
DigitalOut myled(LED1);
DigitalOut myled2(LED2);
//TextLCD lcd(p15, p16, p17, p18, p19, p20);
myled = 0;
myled2=0;
wait_ms(1);
rst1 = 1; //Set reset pin to 1
wait_ms(1);
char X;
while (1) {
if(xbee1.readable()){
wait(1);
myled = 1;
xbee1.scanf("%c", &X);
// X = xbee1.getc();
wait(1);
myled = 0;
if(X=='A')
myled2=1;
is the code correct for RX??
You could try this; The RTC time is sent from one Mbed to another every 5 seconds.
You can remove oled code and use the TextLCD code instead, I have tried on both.
My Xbee's are on p13 and p14
Xbee RTC TX code
#include "TextLCD.h"
#include "OLED32028P1T.h"
OLED32028P1T oled(p28, p27, p29); // Oled Display tx, rx, rs
//TextLCD lcd(p12, p21, p11, p8, p7, p6, p5); // rs, rw, e, d4, d5, d6, d7
Serial xbee(p13,p14); // tx, rx
Ticker t;
void send(){
myled=1;
time_t seconds = time(NULL);
xbee.printf("%d",seconds);
myled=0;
oled.init();oled.clear();oled.setTextBackgroundType(TEXT_OPAQUE);
oled.setFontColor(oled.toRGB(255,255,255));oled.setFontSize(FONT8X12);
//lcd.cls()
oled.printf("Send Time every\n");
//lcd.printf("Send Time every\n");
oled.printf("5 Seconds ");
//lcd.printf("5 Seconds ");
wait(2);
t.attach(&send, 5);
while (1) {
char buffer[40];
oled.locate(0,0);
//lcd.locate(0,0);
strftime(buffer, 40, "%I:%M:%S %p\n", localtime(&seconds));
oled.printf("Time %s",buffer);
//lcd.printf("Time %s\n",buffer);
strftime(buffer, 40, "%a %d %b %Y", localtime(&seconds));
oled.printf("Date %s",buffer);
//lcd.printf("Date %s",buffer);
Xbee RTC RX code
//TextLCD lcd(p12, p24, p24, p30, p22, p23, p11); // rs, rw, e, d4, d5, d6, d7
Serial xbee1(p13, p14);
DigitalOut led1(LED1);
DigitalOut led4(LED4);
struct tm t;
int x;
int count;
char data_buf[10];
//lcd.cls();
wait_ms(10);
while(1){
oled.locate(0,0);
//lcd.locate(0,0);
char buffer[40];
strftime(buffer, 40, "%I:%M:%S %p", localtime(&seconds));
oled.printf("Time %s\n",buffer);
if(xbee1.readable()) {
led1 = 1;count=0;
while (count < 10 ) {
data_buf[count] = xbee1.getc();
count++;
x = atol(data_buf);
set_time(x+1); led4 = 1; // add 1 second for tx/rx delay
led1 = 0;
The mbed board has led so i wish that one of the led shuld glow...and hence i wrote the program (led 3) isit not possible??
Are your Xbees configured properly? Are they using the same PAN ID? Is the Node Identifier correct? Can you check these values with the X-CTU tool?
