11 years, 12 months ago.
Nucleo-L1152RE is not support mbed-rtos yet?
Hello Sir,
I was trying to explore Nucleo-L1152RE with mbed-rtos, but it seems to be that Nucleo-L1152RE is not support mbed-rtos yet, since I encountered many compiler errors:
/media/uploads/stanly88/build-error.jpg
Please give me some hint. Thank you.
Stanly
ST
A world leader in providing the semiconductor solutions that make a positive contribution to people’s lives, both today and in the future.
I just modified mbed-rtos source code to support new target ST Nucleo-L152RE, and now Nucleo-L152RE can run mbed-rtos. if you would like to use and test it, get it by below URL: library: http://mbed.org/users/stanly88/code/mbed-rtos/
Stanly
posted by Stanly Chen 11 Mar 2014
Hello Stanly, the ram is located at 0x2.000.000 . The initial stackpointer is 20014000. If you use the board out of the box it is running with 16MHz. You have to set the OS_CLOCK to 16000000 or use my lib to switch to 32MHz.
Hi Peter, Thank you very much for your advice. I will try your lib.
Warm regards, Stanly
posted by Stanly Chen 12 Mar 2014
Hi , What about F401RE?
posted by Abdessamad El Abbassi 17 Apr 2014
It is more difficult to get the F401 running, because the startup code from ST is using the Sys Tick Timer which is also used by the RTOS. Spend some time to fix it but without success.
posted by Peter Drescher 18 Apr 2014
