12 years, 1 month ago.
please help me
how can i get my mbed with LPC1768 in command mode. the green and red light are flushing alternatively i downloaded the config program say hello but doesn't respond after doing $$$
Hi Mário,
We'll need more detail in order to help you. First, have you had a look at:
- WiflyInterface - particularly under More Details and the "Configure" program.
- Components - Wifly which shows the recommended electrical interface.
- Smartboard Wifly which has some additional software and notes.
But starting at the top, with the Configure program, you can see the sequence of commands involved. How far into this process does your device get? and what is shown on the terminal?
And if I may suggest, you should be able to edit your original post, and if you change the title to indicate this is related to the Wifly module, then it may be a more helpful thread for others to discover as well.
