12 years, 1 month ago.
KL25Z runtime error LED not working with Keil compiler?
Using the KL25Z, i noticed something annoying when i export code containing a runtime error to KEIL :
When we compile/upload/run a program using the online compiler, the runtime error LED starts blinking.
When the same program is exported to KEIL uVision5, compile/upload/run using KEIL, the runtime error LED does not blink.
This can be easily reproduced by importing the HelloWorld example into KEIL and add PwmOut test(NC); to force a runtime error. Compile and upload works fine but the runtime LED does not work.
Is this normal behavior?
