12 years, 1 month ago.
gcc-arm-embedded export for LPC4088
I'm sorry to repost it as a question but I didn't get an answer in the forum.
I'm having trouble to compile mbed projects offline with the gcc-arm-embedded toolchain. I exported the blinking LED Hello World program for both the EA LPC4088 QS and the mbed LPC1768. Building the project for the LPC1768 works, for the LPC4088 I get several errors with the VFP register arguments:
"/usr/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /mbed/TARGET_LPC4088/TOOLCHAIN_GCC_ARM/libmbed.a(pinmap.o) uses VFP register arguments, blink.elf does not"
I tried changing the -mfloat-abi parameter with no success. I also updated the latest mbed libary before exporting. The system is arch linux with the latest 4.8 gcc-arm-embedded. Any suggestions how I can get this work?
Thanks!
12 years ago.
Got it! You need to add the "-mfpu=fpv4-sp-d16 -mfloat-abi=hard" switches to LD_FLAGS in the makefile. Boom.
11 years, 11 months ago.
FP support is still confusing... I try to use emWin Lib and got VFP linker errors because lib types mismatch: mbed used abi-hard, emWin abi-soft. Now NXP has recompiled the emWin Lib to supply also abi-hard, but when exported my mbed testproject today I got a mbed lib with abi-soft. The project settings for the (LPCXpresso) project are still -mfloat-abi=hard, so compiling does not work. Is there a setting for what I get exported?
12 years ago.
Hi Chris,
unfortunately I can't provide a solution. There was no answer here on mbed and I tried searching the web for solutions, but all I could find were hints to the -mfloat-abi parameter which did not help. Let's hope there will be some fix anytime soon.
I have the same problem here. Grateful for any ideas!
posted by Chris Hunt 27 Feb 2014
