12 years, 9 months ago.
Inline member functions
I'm writing a library for a TFT display. I want everything to execute as fast as possible, so I am declaring the member functions for writing to the display with _forceinline as shown below, so that the compiler puts the body of the function in place of the function call.
__forceinline void SomeClass::WriteCommand(unsigned char cmd)
// Output 8-bit data on port _DB
_DB.write(cmd);
// Toggle chip select low
_NCS.write(0);
// Toggle clock low
_DNC_SCL.write(0);
// Toggle write low
_NWR_SCL.write(0);
// Toggle write high
_NWR_SCL.write(1);
// Toggle clock high
_DNC_SCL.write(1);
// Write complete
This is very effective at making things happen faster. The problem is, if I want to have another display library inheriting from my class, the inline functions aren't available to it. Is there any way of having these inline functions available to inheriting classes so I can get the same speed for any inheriting display libraries?
Thanks for your help!
You should put the function's body inside the class declaration, then it will be available to all callers. There's no need for in such case.__forceinline
class SomeClass
void WriteCommand(unsigned char cmd)
_DB.write(cmd);
_NCS.write(0);
// Toggle clock low
_DNC_SCL.write(0);
// Toggle write low
_NWR_SCL.write(0);
_NWR_SCL.write(1);
_DNC_SCL.write(1);
// Write complete
Hi Igor,
Thanks for this. I've actually found that if I put the function's body inside the class declaration AND use _forceinline the code runs 25% faster. Maybe without the _forceinline the compiler decides not to inline some of the functions?
Anyway, problem solved. Thanks for your help.
Tim
