12 years, 10 months ago.
General c++ question
I have a question that is very easy for most (but not me).
I need to use two 8 bit i2c registers to count beyond 255.
These register are 8 bit (d0 - d7), that will give me a maximum count of 255, however I want to record values beyond this. So I have the second 8 bit register to use.
My question is what is the best c code to use both register to store values beyond 255.
I can write and read from both no problem its the maths part I'm not sure on. Do I multiple one register by 255 and add the second like below or is there a better way.
This works but messy
// Write code
rst[0]=0x10;
rst[1]=(rtcset_times >>8);
i2c.write(0xD0,rst,2);
rst[0]=0x11;
rst[1]=(rtcset_times & 0xFF);
// Read code
set[0]=0x10;
i2c.write(0xD0,set,1);
i2c.read(0xD0,cmd,1);
rtcset_times=cmd[0]*255;
set[0]=0x11;
rtcset_times=rtcset_times+cmd[0];
How would I write this in a 'propper' way?
Thank you
It looks to be close to the proper way. I assume 0x10 and 0x11 are internal addresses in the device? Normally they auto-increment their address pointer. So if you write another value, it will be stored to the next location (same for reading). So you could also do:
//rst must be 3 long rst[0]=0x10; rst[1]=rtcset_times >> 8; rst[2]=rtcset_times & 0xFF; i2c.write(0xD0, rst, 3);
And for reading something like:
//cmd must be 2 long set[0] = 0x10; i2c.write(0xD0, set, 1); i2c.read(0xD0, cmd, 2); rtcset_times = (cmd[0] << 8) + cmd[1];
You can also play around with pointers to do it, but this is the standard way.
