13 years, 3 months ago.
Stopping the operation of a thread
I would like to know which command is used to stop the operation of a thread. Use two thread in my program, and specific points of my program, I would kill them.
Thank you. Carlos Alberto.
8 years ago.
Does exists any way to terminate running thread from another running thread?
THX.
13 years ago.
Hey Carlos. I have the same problem. I want to start executing a function in a thread and also be able to restart (stop and start it again) the same function executing also in a thread, doing it e.g for 50 times.
Actually i create and strat my thread by new-operator (pointer) and after executing or after using the terminate-method i kill the stuff with delete. The problem is i am able to do this just for 11 times (although the maximum number of useable threads is set to 7 in rtos library). After 11th execution i cant create a new thread.
So, how have you solved your software problem?
Maybe here is someone other who can help me?
Regards.
Andreas
Hi Andreas,
I solved my problem by managing the shared use of a single resource (serial port). View in: Mutex -> https://mbed.org/handbook/RTOS
I could not stop and start the tread.
Sorry for the lack of response!
Best Regards.
Carlos Alberto
posted by Carlos Alberto Nascimento Filho 12 Mar 2013
10 years ago.
/media/uploads/oceam2/madrid01.jpg
An example how to start and stop a tread:
Hi Carlos,
Take a look at the terminate method:
your_thread_1.terminate()
Cheers, Sam
Thank You!
posted by Carlos Alberto Nascimento Filho 05 Dec 2012
Is it possible to terminate running thread from another running thread?
THX
posted by Rene Klauco 27 Feb 2018
Ok, your_thread_1.terminate (), kills the thread.
And to return to run again?
Thank You. Carlos Alberto.
