It has come to our attention that the very latest version of the firmware for the NBIoT module on the
UBLOX_C030_N211boards has a modification to the AT commands associated with IP sockets commands, specificallyAT+NOSCR,AT+NSOSTandAT+NSORFwill now require/put double quotes around the string portions of their parameters in order to make them V250 compliant, e.g.:AT+NSOCR=”__DGRAM__”,17,45in this commandDGRAMis of type string so should be given in double quotes else error code will be issued.AT+NSOST=NSOST=<socket>,”<__remote_ip_address__>”,<remote_port>,<length>,”<__data__>**”in this command<remote_ip_address>and<data>should be given in double quotes else error.AT+NSORFin the response string of this command,<remote_ip_address>and<data>will be returned in double quotes.The Cellular API drivers (ublox-at-cellular-interface-n2xx and ublox-cellular-base-n2xx) have not yet been update to handle this. Update versions of the drivers will be posted tomorrow (19 September 2017),
