Hello Community,
I am currently evaluating the board of Maxim Integrated MAXREFDES100#. As part of my thesis, I would like to examine whether there is the possibility of using BLE for data streaming.
The supplied software is fully functional and can already transfer data:
MAX32620HSP (MAXREFDES100) RPC Example for Graphical User Interface
Of course, only smaller data packets over a longer period like Temperatur or precalculated Heart Rate values.
I am aware that BLE is not suitable and has not been designed to transmit data continuously. Nevertheless, I would like to try to transfer the ECG raw data also via the BLE interface.
So that I can check whether my data has been arrived completely and correctly in time (prerequisite for ECG data), I have developed the following test setup:
Currently, I store data of a sine wave to a large FIFO and transfer 20-byte sine packets to a characteristic. So far everything works wonderfully. Using an Android device and a BLE sniffer I catch the data packets and check if the sine has any interruptions. The following graphic is taken from a longer measurement: (I have tested my FIFO and the sine datas are complete without any inerruption): This is a capture of my Android and my BLE Sniffer: Data packets are missing.
![/media/uploads/Emin/unbenannt.png /media/uploads/Emin/unbenannt.png](/media/uploads/Emin/unbenannt.png)
Further measurements show that the errors do not occur sequentially, they can always be found at different times.
![/media/uploads/Emin/unbenannt2.png /media/uploads/Emin/unbenannt2.png](/media/uploads/Emin/unbenannt2.png)
Since my phone and my Adafruit BLE sniffer have identical errors in the same place, the data packages on the board-side must be corrupt. I suspect they are lost at some protocol level (GAP maybe?).
Interestingly, errors affect at least 200 following bytes (256 bytes data are a complete sine). This means that at least 10 data packets each 20 Bytes would have to be in order to get such a graphic.
- What options are there for continuously sending data via the BLE interface?
- Is it possible with the BLE_API to send the data directly via L2CAP without GATT/ATT?
- Are there any more protocoll-levels that allow data streaming? (So with acknowledgment like TCP for completeness and chronological correctness)
Excuse my bad English and best regards,
Emin
Hello Community,
Import programHSP_RPC_GUI
Last commit 25 Apr 2017 by
Maxim Integrated
Of course, only smaller data packets over a longer period like Temperatur or precalculated Heart Rate values. I am aware that BLE is not suitable and has not been designed to transmit data continuously. Nevertheless, I would like to try to transfer the ECG raw data also via the BLE interface. So that I can check whether my data has been arrived completely and correctly in time (prerequisite for ECG data), I have developed the following test setup:
Since my phone and my Adafruit BLE sniffer have identical errors in the same place, the data packages on the board-side must be corrupt. I suspect they are lost at some protocol level (GAP maybe?). Interestingly, errors affect at least 200 following bytes (256 bytes data are a complete sine). This means that at least 10 data packets each 20 Bytes would have to be in order to get such a graphic.
- What options are there for continuously sending data via the BLE interface? - Is it possible with the BLE_API to send the data directly via L2CAP without GATT/ATT? - Are there any more protocoll-levels that allow data streaming? (So with acknowledgment like TCP for completeness and chronological correctness)
Excuse my bad English and best regards, Emin
