I tested all the LPC1114 GPIO pins for
1. Low going edge triggers an IRQ or not 2. Did the selected pin cause any compiler errors 3. Measured the pull-up current in each case
I tested all of the pins on two separate mbed LPC1114 modules to confirm the results.
Here is the test code (note: I just incremented the PB's each time to check the input. For pin 11, I changed the LED indicator to pin 10 and made pin 11 and input)
Here are the results
