I tested all the LPC1114 GPIO pins for
1. Low going edge triggers an IRQ or not 2. Did the selected pin cause any compiler errors 3. Measured the pull-up current in each case
I tested all of the pins on two separate mbed LPC1114 modules to confirm the results.
Here is the test code (note: I just incremented the PB's each time to check the input. For pin 11, I changed the LED indicator to pin 10 and made pin 11 and input)
#include "mbed.h" // this uses IRQ's to check for PB's going low DigitalOut LEDS1(dp11); InterruptIn PB1(dp1); InterruptIn PB2(dp2); InterruptIn PB3(dp4); InterruptIn PB4(dp5); InterruptIn PB5(dp6); void PB1isr(void) { LEDS1 != LEDS1; } void PB2isr(void) { LEDS1 =! LEDS1; } void PB3isr(void) { LEDS1 =! LEDS1; } void PB4isr(void) { LEDS1 =! LEDS1; } void PB5isr(void) { LEDS1 =! LEDS1; } int main() { PB1.mode(PullUp); PB2.mode(PullUp); PB3.mode(PullUp); PB4.mode(PullUp); PB5.mode(PullUp); PB1.fall(&PB1isr); PB2.fall(&PB2isr); PB3.fall(&PB3isr); PB4.fall(&PB4isr); PB5.fall(&PB5isr); LEDS1 = 1; wait (3); LEDS1 = 0; wait(3); do { wait_ms(250); __WFI(); wait_ms(250); } while(1); }Here are the results
