I compiled and successfully tested the program via mbed-cli. I exported project to eclipse IDE, than compiled successfully again Now I tried to debug the application and seems that the only way is through openocd. The configuration is the following:
So, I downloaded openocd.0.10.0 for windows and tried it.
I get the following error:
openocd.0.10.0 console output
c:\Program Files\openocd-0.10.0\bin-x32> c:\Program Files\openocd-0.10.0\bin-x32>openocd.exe -f ../scripts/board/NUCLEO-F767ZI.cfg Open On-Chip Debugger 0.10.0 Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html srst_only separate srst_nogate srst_open_drain connect_assert_srst Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 2000 kHz adapter_nsrst_delay: 100 srst_only separate srst_nogate srst_open_drain connect_assert_srst Info : Unable to match requested speed 2000 kHz, using 1800 kHz Info : Unable to match requested speed 2000 kHz, using 1800 kHz Info : clock speed 1800 kHz Info : STLINK v2 JTAG v28 API v2 SWIM v18 VID 0x0483 PID 0x374B Info : using stlink api v2 Info : Target voltage: 3.234301 Info : STM32F767ZITx.cpu: hardware has 8 breakpoints, 4 watchpoints Info : accepting 'gdb' connection on tcp/3333 Info : device id = 0x10006451 Warn : STM32 flash size failed, probe inaccurate - assuming 2048k flash Info : flash size = 2048kbytes Error: auto_probe failed Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'. Error: attempted 'gdb' connection rejectedSomeone has debug successful?
