Small RS232 Serial SMD breakout board at Sparkfun
02 Sep 2010 . Edited: 22 Sep 2010
I may be the last person still using serial. Sparkfun has a SMD RS232 breakout board that looks handy if you need a serial connection with a level converter. It comes assembled and has two LED activity indicators. No need to wire up a MAX232 and add caps! When you wire it up from the breakout PCB to mbed connect TX-RX and RX-TX and use 3.3V for VCC. (i.e, not 5 for VCC and not TX-TX and RX-RX)
02 Sep 2010
sometimes I use an old laptop as a terminal. It has no USB so this is very handy :)
02 Sep 2010 . Edited: 02 Sep 2010
25 Jan 2011
/media/uploads/4180_1/p_rs232.jpg
If you need to use handshaking, take a look at this one http://www.pololu.com/catalog/product/126
23 Nov 2012
Thanks Jim for the recommendation, I bought one from Coolcomponents.co.uk, works a treat!
02 Jul 2013
You’re not the last person using a serial. I work with embedded systems and it’s still widely used in the industry as a standard of choice. Thank you for the recommendation, it certainly looks like it can be handy, I’ll have a look whenever I get a chance.
http://www.7pcb.co.uk
20 Jun 2013
We use serial all the time. Almost every embedded type processor comes with several serial ports. Something else that's hard to find are serial standalone modems. Most mainframe I/O devices use serial for connecting to testing equipment. It will never go away.
You need to log in to post a reply
