Timer at counter mode
03 Jun 2010
I'm using Mbed and trying to use CAP2.0 events (rising and falling edges) to increment timer2, instead of the PCLK rising edge. I've connected an external signal to pin p30 (CAP2.0/p0.4). I've configured register CTCR according to user manual, but it still doesn't work. Am I missing anything?
It's rather hard to debug using Mbed so I'm reseting the counter every 108 usec (using PWM interrupt- which works perfectly) and sending the value timer2  TC register using serial comunication. the results are showing that the PCLK is still used to increment the TC.
here's my code, I also used CMSIS package functions:
//Config P0.4 and P0.5 as CAP2.0,CAP2.1
    PinCfg.Funcnum = 3;
    PinCfg.OpenDrain = 0;
    PinCfg.Pinmode = 0;
    PinCfg.Portnum = 0;
    PinCfg.Pinnum = 4;
    PINSEL_ConfigPin(&PinCfg);
    PinCfg.Pinnum = 5;
    //config timer2 for capture int counter mode
    CLKPWR_ConfigPPWR (CLKPWR_PCONP_PCTIM2, ENABLE); //enable timer 2 clk
    CLKPWR_SetPCLKDiv (CLKPWR_PCLKSEL_TIMER2, CLKPWR_PCLKSEL_CCLK_DIV_1); //select PCLK=72MHz
    LPC_TIM2->TC =0;
    LPC_TIM2->PC =0;
    LPC_TIM2->PR =0;
    LPC_TIM2->CTCR = 0x3;//
    TIM_ResetCounter(LPC_TIM2);
    TIM_Cmd(LPC_TIM2,ENABLE);
Any ideas?
07 Jun 2010
Anyone? I really need help with this. was anyone able to operate any of the timers in counter mode using mbed?
07 Jun 2010
I found the problem and it's relevant to anyone trying to use counter mode:
The header file LPC17xx.h had a wrong definition of timer block registers in the past. The CTCR register (needed to switch into counter mode) was at a wrong address. It was caused by a line
      uint32_t RESERVED1[24];
instead of the correct version below.
/*------------- Timer (TIM) --------------------------------------------------*/
typedef struct
 __IO uint32_t IR;
 __IO uint32_t TCR;
 __IO uint32_t TC;
 __IO uint32_t PR;
 __IO uint32_t PC;
 __IO uint32_t MCR;
 __IO uint32_t MR0;
 __IO uint32_t MR1;
 __IO uint32_t MR2;
 __IO uint32_t MR3;
 __IO uint32_t CCR;
 __I  uint32_t CR0;
 __I  uint32_t CR1;
      uint32_t RESERVED0[2];
 __IO uint32_t EMR;
      uint32_t RESERVED1[12];
 __IO uint32_t CTCR;
} LPC_TIM_TypeDef;
07 Jun 2010
Thanks for raising this, I've filed it as a bug.
